설치시 에러가 납니다.
Fatal error: Cannot redeclare print_outlogin() (previously declared in /home/kmfootball/public_html/bbs/outlogin.php:75) in /home/kmfootball/public_html/bbs/outlogin.php on line 179
<outlogin.php>
44 * 외부로그인 모양을 바꾸시려면 outloing_skin 디렉토리 내의 README.TXT 파일을
      읽 어 주시기 바랍니다.
45*
46*******************************************************************************/
47 global $member, $_head_php_excuted, $REQUEST_URI, $_zb_lib_included, $H
                TTP_SESSION_VARS, $total_member_connect, $total_guest_connect;
48 global $a_member_join, $a_member_modify, $a_member_memo, $member_m
                emo_icon, $memo_on_sound, $a_logout, $a_login, $id, $PHP_SELF, $_outlogin
                _include;
49
50 if(eregi(":\/\/",$_zb_path)||eregi("\.\.",$_zb_path)) $_zb_path ="./";
51
52
53 // outlogin.php 파일이 include 되었는지를 체크
54 if(!$_outlogin_include) {
55 $_outlogin_include = TRUE;
56 } else {
57 return FALSE;
58 }
59
60 // 처음에 include 되었을때 필요한 파일을 include 하는 부분
61 if(!$_head_php_excuted&&!$_zb_lib_included) {
62
63 // 제로보드 디렉토리 인지 체크
64 if(!file_exists($_zb_path."lib.php")) {
65 echo "제로보드 디렉토리가 아닙니다";
66 return;
67 }
68
69 // _head.php 읽음
70 @include $_zb_path."_head.php";
71
72 }
73
74 // 외부로그인 출력 함수
75 function print_outlogin($skinname = "default", $group_no = 1, $level = "10") {
76 global $member, $_head_php_excuted, $REQUEST_URI, $HTTP_SESSION_VARS, $total_member_connect, $total_guest_connect, $_zb_path, $_zb_url;
77 global $a_member_join, $a_member_modify, $a_member_memo, $member_memo_icon, $memo_on_sound, $a_logout, $a_login, $id, $PHP_SELF;
78
79 if($level < $member[level]) {
80?>
168
169 }
170
171 $a_member_join = "<Zeroboard";
172 $a_member_modify = "<Zeroboard";
173 $a_member_memo = "<Zeroboard";
174 $member_memo_icon = "<Zeroboard";
175 $memo_on_sound = "";
176 $a_logout = "<Zeroboard";
177 $a_login = "<Zeroboard";
178
179 }
제로보드연동모듈은 http://www.kmfootball.zon.to/KChatIRC/bbs/config.php
저로보드연동모듈을 다운받아서 /KChatIRC/아래에 bbs방을 만들고 압축을 푼 config.php를
업로드 하였습니다.
<기타환경설정>
[설치경로*]  http://www.kmfootball.zon.to/KChatIRC/
[연동모듈]  zeroboard
[연동모듈경로]  http://www.kmfootball.zon.to/bbs/
[연동모듈경로]  /home/kmfootball/public_html/bbs/
[나가기경로]    http://www.kmfootball.zon.to /
설치상 뭔가 잘못된것이 있습니까
조언부탁드립니다.
질문/답변란을 검색해보니 경로문제라는 답이 많던데 어떻게 해야 해결 할수 있는지요..
부탁드립니다.
    • head.php 에서 print_outlogin() 이 두번 호출된듯하네요
    • 05-06-11
그누보드 새로운 버전이 나왔습니다 1 05-06-17
질문입니다. 1 05-06-17
제목읽기에서 멈추고.... 1 05-06-13
제로보드를 사용하고 있는데요! 2 05-06-12
irc 에서 포트는 1 05-06-12
설치시 에러가 납니다. 1 05-06-11
index.php 7 05-06-11
설치시 에러가 났습니다 1 05-06-11
잘쓰다가 오류가 생겼습니다. 1 05-06-11
또 질문입니다. 1 05-06-05
질문있습니다. 1 05-06-05
이렇게 에러가 납니다. 2 05-06-02
프레임 사용시 스크립트 에러 발생 1 05-05-30
처음이에요..setup질문입니다. 1 05-05-28
설치중인데요~ 질문드립니다. 1 05-05-24
안녕하세요.. 2 05-05-23
메인 링크목록이요.. 1 05-05-21
킴스7 연동모듈에 관해 1 05-05-20
안됩니다,.. 1 05-05-17
도와주세요^^ 왕왕초보임다 ! 1 05-05-17
내용에 html 사용시 1 05-05-16
헤더 풋 적용을 하면 이상합니다. 1 05-05-15
답변좀해주세요.. 1 05-05-09
전송실패에 대한 문의요 10 05-05-09
보안IT사주클럽심리톡톡역사과학지원톡톡
